Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Octavia III
 Lehekülgi:  1  ..  7  8  9  10  11  ..  17
Pealkiri: Octavia III (Vastuseid: 417 | Vaatamisi: 79209)
Malemajastaar
Registreerunud 20.01.08
Auto: SIII
postitati 14.06.13 12:53 Tsiteeri
Algselt postitas: ews
kehvad pildid aga siin nad on..
Tänud ews, kuid ega see teine pilt eriti loetav küll pole kui pealkiri väljaarvata :)
ocu
Registreerunud 10.03.12
Auto: Octavia III combi 1,6TDI
postitati 15.06.13 16:17 Tsiteeri
kummaline aga pean ise ka tunnistama, et algsete promo piltide peal nägi uus octavia väga isuäratav välja. nüüd nähes neid liikluses ei tekita enam üldse emotsiooni. endal on plaanis uuem kõrgem universaal osta ja octavia oli suht nr1 kanditaat ja seda 1,8TSI 4x4 näol aga nüüd ma ei tea pigem ei. vanem tundub hetkel ilusam - viimased vana näoga scoudid praegu hea hinnaga - päris hädas kohe.:P
kui uus octavia tundub mulle selline, et pildil ilus ja aja möödudes muutub igavamaks ja näotumaks siis nt teine mark (ärge näkku lööge:)) subaru outback mis tundus mulle 2010 aastal kole nagu öö - siis aja möödudes on see muutunud kuidagi ilusamaks oma põdranäoga :D
ei tea see minu kiiks ja puhas otsustusvõimetus.
lihtsalt tahtsin välja elada
HenriR
Registreerunud 14.02.13
postitati 26.06.13 10:53 Tsiteeri
Auto välimus
Minu meelest oli ka eelmisega sama lugu- kui osta madalas varustuses auto, näeb välja odav. Kui aga investeerida rohkem raha, võib saada väga kena auto. Ma isiklikult pole veel ühtegi uut octaviat meie tänavatel näinud, mis oleks sellises varustuses nagu ise ostaks. Aga komplekteerida saab väga kena auto kokku :))
Ja Outback oma nelikveoga on kindlasti kohe üle aga kahjuks autos olev nö. tehnika ( nt. käigukast) on võrreldes skodaga kindlasti aegunud.
ocu
postitati 26.06.13 20:57 Tsiteeri
nõus outbacki tehnika teemal!
ilmselt tuleb oma mondeoga veel lasta aasta või paar edasi - ehk tuleb selle aja sees miskit paremat silmapiirile :P
enzo
Registreerunud 09.11.10
Auto: Cupra Leon SP 4Drive 2024
postitati 28.06.13 05:57 Tsiteeri
Uus RS tuleb ikkagi 162 kw. Nii on kirjas uues Tehnikamaailmas ja ka Skoda Tsehhi kodulehel - http://www.skoda-auto.cz/models/nova-octavia-rs. Sealt Googlega tõlgitud lõik:
Engines
Plenty of power to the new SKODA Octavia RS provides two new engines. Under the bonnet is either a two-liter gasoline engine with an output of 162 kW (220 hp) or a two-liter diesel engine with an output of 135 kW (184 hp). 2.0 TSI petrol engine in conjunction with manual shifting six-speed transmission allows the Octavia RS accelerates from 0 to 100 km / h in just 6.8 s Top speed is 248 km / h and is thus about 6 km / h higher than it was the second generation of the Octavia RS. With the new diesel engine 2.0 TDI Octavia RS accelerates from 0 to 100 km / h in 8.1 s, top speed of this version is 232 km / h
The new SKODA Octavia RS is fitted with sports suspension that ensures optimum performance. Rear wheels using a newly developed multi-link axle. Precision track guidance provided by the front MacPherson-type suspension with lower triangular shoulders.
Eesti keeles ka, aga see tõlge ei kannata kriitikat:
Mootorid
Palju võimu uus Skoda Octavia RS pakub kahe uue mootoriga. Kapoti all on kas kahe-liitrise bensiinimootori võimsus on 162 kW (220 hj) või kahe-liitrine diiselmootor võimsusega 135 kW (184 hj). 2,0 TSI bensiinimootor koos käsitsi käike kuuekäiguline käigukast lubab Octavia RS kiirendab 0-100 km / h vaid 6,8 s. Tippkiirus on 248 km / h ja on seega umbes 6 km / h suurem kui see oli teine põlvkonna Octavia RS. Uue diiselmootoriga 2.0 TDI Octavia RS kiirendab 0-100 km / h 8,1 s, tippkiirus on see versioon on 232 km / h
Skoda Octavia RS on varustatud sport vedrustus, mis tagab optimaalse jõudluse. Tagumised rattad kasutades hiljuti väljatöötatud multi-link sild. Precision track suuniseid, mille ees MacPherson-tüüpi vedrustus alumise kolmnurkse õlgadele.
Rage
Registreerunud 10.02.07
Auto: XF S
postitati 28.06.13 13:05 Tsiteeri
no ok, 220 on siis vähe ikkagi parem number, huvitav mis see 0st 100ni DSG kastiga tuleb..
Vaata kasutaja profiili Saada kasutajale U2U Skype Kasutaja Telefoninumber
M8DSwordfish
Registreerunud 10.05.10
Auto: Kodiaq Sportline’20, Kodiaq RS ‘23, Rapid Spaceback '14.
postitati 29.06.13 04:19 Tsiteeri
Nullist sajani vast polegi teema, kuna juba praeguse 147 kW paigaltstardist mahapanemine on pehmelt öeldes problemaatiline.(siin oleks 4x4 omal kohal) Ennem pigem huvitaks kiirendus 60-120 mis näitaks mis see komplekt ka tegelikult väärt on. See, et lõppkiirus on "tervelt" 6 km tunnis suurem kui praegusel mudelil, on reaalselt naerukoht. Tahaks küll näha inimest keda see meie oludes tegelikult huvitab. Inimene kes ostab Skoda (RS-i või mitte) ei plaani kindlati seda tundide kaupa niisuguse kiiruse juures ekspluateerida. Selle jaoks on teised tootjad ja mudelid. Eneseteadvuse kõdistamiseks võib see muidugi argument olla aga reallselt.... Parem oleks ikka nelivedu olnud... 1,8 ja 4x4 ei ole see teema. Varustust ja sisu sellist ei saa, maksa palju tahad. Aga tegelikult on ju kõik arusaadav. niigi astub uus Octavia juba liialt paljudele oma konserni autodele kanna peale. See oleks ilmselgelt liig, mis liig... :P
Puuriit
Registreerunud 10.12.07
Auto: VW Passat B8 Highline
postitati 29.06.13 14:03 Tsiteeri
Ühinen eelpool kõnelejatega, et algselt fotol nähtu ning hilisem salongis kaetu erinesid kui öö ja päev - seda halvas mõttes. Esinduse näidisauto võiks ju peegeldada varustuse valikuvõimalusi ning sportvedrustus/pakett ja 18" veljed peaksid O3 oluliselt atraktiivsemaks muutma.
marxveix
Registreerunud 11.05.13
Auto: Skoda Octavia III Combi 1.4TSI
postitati 30.06.13 19:19 Tsiteeri
Uus Octavia kombi on ka lõpuks Eestis kohal...
http://media.autotalli.com/images/articles/normal/skoda-octavia-combi-2013-03.jpg
Kus kohas ta siis kohal on (tallinna auto100 polnud haisugi)?
tnx
Registreerunud 07.05.12
postitati 01.07.13 05:54 Tsiteeri
Kui esinduses oleks väljas ainult maksimumvarustuses autod, siis saabuks see halvas mõttes öö ja päeva lihtsalt veidike hiljem, pärast tehingu sooritamist. Sest olgem ausad, neid on ikka vähe, kes 35-40k eest octaviat ostma lähevad, selle raha eest on turul konkurentsi piisavalt. Müügitaktikana oleks see muidugi edulisem variant, sest pärast ostu saabunud pettumuse neelab enamus inimesi alla, enne ostu on aga salongist väga lihtne järgmisse kohta jalutada.
HenriR
postitati 01.07.13 12:32 Tsiteeri
Tegelikult asi nii hull pole, 30 tuhande eest saab igati täis poogitud uue Octavia kõigi lisadega. Kui täiesti lolliks minna, siis saab tõesti võib-olla 35 ka kätte :)
tnx
postitati 02.07.13 05:44 Tsiteeri
Vahet eriti pole, ka 30k eest on valikus igati korraliku varustusega Superb, Passat, Insignia, Legacy, Avensis, Mondeo, 508, Optima, i40 jne, mis kõik peavad end Octaviast klassi võrra kõrgemaks autoks. Selle rahaga kannatab hädapärast isegi Audi, BMW või Volvo poodi vesistama minna. Kui aga võtta 15k eest baasvarustuses mudel, siis lähevad reklaamides toodud argumendid palju paremini täkkesse, kuna siis on konkurentideks hoopis teised mudelid.
ocu
postitati 02.07.13 07:04 Tsiteeri
enam paremini ei anna asja kokku võtta kui tnx seda tegi :D
nii et tänx
HenriR
postitati 02.07.13 10:44 Tsiteeri
Valikut palju
Ei vaidle üldse vastu, eks see ongi maitse asi :))
Sellegi poolest vähemalt minu silmis pooled sellest nö. valikust kukuvad juba aegunud tehnika pärast välja. Ja me võime võrrelda neid autosid küll aga vähemalt minu silmis on paar argumenti, mis siin octavia kasuks räägivad (minu jaoks):
1) Suuremat autot pole enam tegelikkuses vaja, ka tagaistmel on nüüd täiesti mõistlik ruum
2) 30 tuhande eest võid sa saada jah korralikus varustuses nt. superbi aga küsimus on, mida korraliku varustuse all mõelda. 1.8 tsi DSG-ga ja nahkistmetega Superbi vaatasin poes, allahindlus oli 30 peale. Aga 30 eest Octaviale saaksid sa absoluutselt kõige uuema tehnika ja varustuse, mida üldse võimalik saada. (panoraamkatus, pagass sulgub ise, adaptiivne kiirushoidja, 4x4 jne jne.) Seega varustuse& hinna suhe on täiesti paigas minu silmis.
Aga veelkord ütlen, see täiesti maitse asi, tõin argumendid lihtsalt välja :)
marxveix
postitati 02.07.13 16:19 Tsiteeri
Täna käisin ja vaatasin combi üle, sinine jättis natuke lahja mulje.
Konkreetsel isendil oli:
Reguleeritav käetugi esiistmete vahel, laekaga.
Konkreetsel isendil polnud:
Elektrilised aknatõstukid taga.
Hinnakirja ja varustuse järgi sellist tellida ei saa, käetoe saab ainult alates ambition tasemest, millel ka tagumises elektriaknad kohe olemas.
Enda tellitud combil poleks ka ambition taset vaja olnud kui oleks lisvarusutsena saanud selle lisada.
HenriR
postitati 03.07.13 13:30 Tsiteeri
RS
Uue RSi sisu näeb küll ikka eriti maitsekas välja:
https://www.facebook.com/photo.php?fbid=466394996786300&set=a.164369073655562.39021.142062625886207&type=1&theater
mxrt
Registreerunud 13.03.08
Auto: RS / Scout
postitati 03.07.13 19:51 Tsiteeri
Algselt postitas: HenriR
Pole just liiga sportliku väljanägemisega....aga vöiks... :)
HenriR
postitati 03.07.13 19:58 Tsiteeri
Liiga sportlik jah pole, minu meelest just täiskasvanulikum :))
Rainz88
Registreerunud 05.02.13
Auto: O3 Combi 1.2TSI
postitati 03.07.13 21:31 Tsiteeri
Algselt postitas: marxveix
Combi siis olemas salongis? Millal autot k2tte lubati?
T2nud
marxveix
postitati 04.07.13 06:24 Tsiteeri
Algselt postitas: Rainz88
T2nud
Olemas jah. Augusti keskel saan enda 1.4tsi-ga combi kätte.
Pildid ka, kõige ligilähedasem minu omale mille netist leidsin:
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea0a132dd.jpg
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea0c3a46f.jpg
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea0e02a43.jpg
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea101539c.jpg
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea1cba753.jpg
http://www.skoda-plus.com/i/carpics/4/171/800x600/51b5ea26c9b82.jpg
Ambition, veljed samad, ilma mootoritähiseta, see vist ainult tava kliirensiga?
rstdi
Registreerunud 05.01.07
Auto: RS TFSI dsg O2 11, Cupra ST 300 4drive 17
postitati 08.07.13 11:14 Tsiteeri
mulle ka nn reaalsuses see uus octavia väljast väga ei meeldi, sisemus on päris OK.
Samas uus Scout väidevalt peaks tulema 135kw mootoriga (diisel). Kui nad seda DSG ka suudavad pakkuda, siis see võiks päris huvitav masin olla.
Praegune 103kw aeglane, kuigi talvel 4veoga seda aeglust startides ei näe, pigem vastupidi.
Malemajastaar
Auto: SIII
postitati 11.07.13 13:49 Tsiteeri
Autoleht käis Tsehhis - http://www.skoda.ee/failid/4ff50dcafc79e5e76d7804ba753475d3.pdf
marxveix
postitati 23.07.13 20:36 Tsiteeri
Vaatasin auto mõõte ja jäi silma pagasniku pikkus. Hämmastaval kombel on see combil lühem, miks nii?
hatch
http://www.skoda.ee/failid/e2594fc4f71da20f7c166319e7006522.jpg
combi
http://www.skoda.ee/failid/82588281ee798f6bc4424276118516a0.jpg
edit: Ise küsin, ise vastan. Pakiruumi põhi ongi combil 34mm võrra lühem, mõõdulindiga mõõdetud :(
pepe
Registreerunud 06.04.10
Auto: VW
postitati 06.08.13 09:27 Tsiteeri
http://www.e24.ee/1323056/uute-autode-muugis-tousis-juulis-uueks-liidriks-skoda
Eesti uute autode müügi eelmiste kuude liider Toyota pidi juulis tunnistama Skoda paremust. Skoda müüs uusi sõiduautosid 210 tükki, Toyota aga 205. Kolmandale kohale platseerus Volkswagen 155 sõiduautoga, vahendab autode müügi- ja teenindusettevõtete Eesti liit.
Oluline muutus toimus ka mudelite paremusjärjestuses, sest esimest korda üle mitme kuu ei mahtunud esikolmikusse mitte ühtegi maasturit. Kolm enim ostetud mudelit olid juulis Skoda Octavia (115), Toyota Avensis (67) ja Honda Civic (59).
marxveix
postitati 16.08.13 21:03 Tsiteeri
Auto sain täna kätte ja masinaga igati rahul. Loodan, et peab hästi vastu :P
XMB Škoda Club Edition
[PHP: 18.5% - SQL: 81.5%]
