Pealkiri: Veakoodid superb 2003 (Vastuseid: 2 | Vaatamisi: 3396)
maandy
Registreerunud 12.09.08
postitati 18.11.09 15:22 Tsiteeri
Tere
Selline küsimus et kust saab infot mida miski veakood tähendab jne. Sain autost kätte mõned veakoodid nagu :
Chassis Type: 3U - Skoda Superb
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 08 -------------------------------------------------------
Controller: 3U0 907 044 A
Component: CLIMATRONIC S B5 C 2004
Coding: 17000
Shop #: WSC 00028
4 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 17 -------------------------------------------------------
Controller: 3U0 920 841 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 31115
Shop #: WSC 80152
1 Fault Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
1 Fault Found:
Address 55 -------------------------------------------------------
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00005
Shop #: WSC 73430
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
Kas on mingi raamat või fail kellegil et mis miski number jne tähendab?
Tänades
Kristen
Wygla
Registreerunud 09.03.06
Auto: Octavia
postitati 18.11.09 15:59 Tsiteeri
http://wiki.ross-tech.com/index.php/Category:Fault_Codes
maandy
postitati 19.11.09 19:40 Tsiteeri
tänud!
XMB Škoda Club Edition
[PHP: 18.4% - SQL: 81.6%]
