Pealkiri: M: VAG COM diagnostika kaabel(UUS) 325.-(MÜÜDUD) (Vastuseid: 3 | Vaatamisi: 3063)
Wygla
Registreerunud 09.03.06
Auto: Octavia
postitati 15.01.10 09:18 / uuendati 16.01.10 11:43
Mis programmiversioon on?
joosep666
Registreerunud 14.01.10
postitati 15.01.10 12:12 / uuendati 16.01.10 11:43
Rohkem infot:
Features:
Essential kit for Audi, Seat, Skoda and Volkswagen owners to connect your PC to your car for on-board diagnostics (OBD)
Support VAG version 409.1 or older VAG is a windows-based diagnostic software that can turn your PC into a sophisticated diagnostic tool
Fully automatic support for 2002+ Audi models with dual K-lines
High precision molded diagnostic connector made to fit all Audi/VW vehicles, even those with "tight" trim around diagnostic socket
Built-in electronic Isolator to prevent damage to car and computer
Technical Specification:
OBDII plug: 16-pin to car
USB plug: to computer or PDA
2 K-Lines & L-Line (KKL Interface)
Length of OBDII USB cable: 140cm
Supported Software
Rotech VAG-COM: Versions: 3xx, 4xx
ShadeTree Software ProDiag 1.0x (for PalmOS) Serial Cable : Palm III, Palm V/Vx, Palm VII, HandSpring Visor Series, HandEra TRG, SONY
VAG Diagnose (for DOS) :Supports powerful Direct Memory Access (DMA) which allows users to modify RAM/EEPROM/SEEPROM directly through the cable without ever touching the controller cover
REVO Lemmiwinks ECU Tuning
APR Immobilizer Information Reader
ECU Tuning Applications
Other VW diagnose/tuning software
janas
Registreerunud 22.07.08
postitati 16.01.10 02:01 / uuendati 16.01.10 11:43
Vabandage kui see on rumal küsimus aga kui ohutu on see tarkvara masinale? Ja kas tehase poolt on antud tarkvara aksepteeritud või heakskiidetud?
joosep666
postitati 16.01.10 11:43 / uuendati 16.01.10 11:43
Ei ole kuulnud küll, et see kellegi autole oleks halba teinud. Pigem siiski head :)
XMB Škoda Club Edition
[PHP: 17.9% - SQL: 82.1%]
