Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Roomsteri tagaluuk
Pealkiri: Roomsteri tagaluuk (Vastuseid: 0 | Vaatamisi: 2826)
Puskin
Registreerunud 19.11.06
Auto: Skoda Roomster
postitati 09.07.11 21:09 Tsiteeri
Roomsteri tagaluuk
Tere.
Loodan et postitasin õige koha pääle.
Jutt siis järgmine, tagaluugi lukustus muidu kui nuppu vajutada siis teeb plõks ja tuleb lahti aga minul mitte ei ei tee plõks vaid teeb sellist heli nagu miski "peksab üle" ja pärast seda ei jää kinni isegi kui füüsiliselt on kinni siis andur näitab et luuk lahti, kas viga võib olla väheses õlitamises?
2aastat tagasi oli sama jama aga sis vaheteti garantii korras välja nüüd garantii möödas ja kardan et raha röövitakse liiga ära.
Kas kellegil on kogemusi säänse asjaga???
Tuttav mehaanik arvas küll et äkki elekter ei suuda konksu suruda (õlitus vähene) ja seepärast jonnib aga mis on teie tarkade arvamus?
Omaarust oleme Me kõik targad!
XMB Škoda Club Edition
[PHP: 46.0% - SQL: 54.0%]
