Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Deprecated: Implicit conversion from float 125902.99999999999 to int loses precision in /data01/virt4271/domeenid/www.audiclub.ee/skoda/viewthread.php on line 167
Eesti Skoda Klubi - O: MYYA: Skoda Oktavia Kombi, 1999 varuosadeks
Pealkiri: O: MYYA: Skoda Oktavia Kombi, 1999 varuosadeks (Vastuseid: 5 | Vaatamisi: 3049)
Lihtsalttiit
Registreerunud 30.06.13
postitati 30.06.13 12:09 / uuendati 03.11.13 12:22
Millegip2rast laseb ainult ostu soovi panna, aga see selleks.
Mark: Skoda Oktavia Kombi 1999
Mootor: 1.6 MPI AKL 74 kW
Ls: 250 *** km
V2rv: Tumesinine
Mugavusvarustus: 4x El. aknad, el.peeglid,
Auto on parema k]ylje pauguga, parem esi poritiib, ja paremad uksed on puru, poritiib on muidugi v2hesel m22ral muljuda saanud, h2da p2rast veel k6lbab. ukse polstsid samuti purunenud, ja parema eess6itja poolne klaas samuti katki. K.kast on juba omastatud.Mootor sai eelmisel sygisel uue hammasrihma ja hoolduse(6li, kyynlad), p2ris t2itsa ohe ka vanarauda ei tasu viia, vb on kellelgi vaja olemasolevaid osasid. Et auto asub t2iega Eesti kagu nurgas, ja ise liigun pidevalt marsruudil, Obinitsa-V6ru-Saverna-Tartu-P6ltsamaa-Paide-Kose-Tallinn-Keila-Paldiski. M6nikord tekib isu ka Viljandi kaudu Tallinna s6ita. Aga, suuremate asjade jaoks pead ikka ise kohale tulema, sest veokaga ma ei liigu.
Pakkuda siis j@rgmised osad:
Esistange
Kapott
Pagasiluuk
Vasak esiuks (klaas sees, el. ajamiga)
Vasak tagauks (klaas sees, el. ajamiga)
Vasak esi poritiib
Tagumine kaitseraud/pamper/stange kuidas kellele
Tagatuled
Esituled
Mootor (1.6 MPi 74 kW, AKL eile liikus ja k2ivitus ja t66tas)
Vasak el.peegel
Esimene klaasipuhasite hoovastik koos mootoriga
Tag. kojamehe mootor
Starter
Iluv6re
Istmetega on nii, et vb kasutan ise need 2ra
Ja k6ik muud ylej22nud pudinad mida kellelgi vaja on, andke teada ainult.
Pildid:
http://fotoalbum.ee/photos/Lihtsalttiit/sets/1374373
HINNAD on kokkuleppelised !
tel:56979400
5218515
Lihtsalttiit
postitati 01.07.13 16:36 / uuendati 03.11.13 12:22
Homme liigun sunnal Võru-Tallinn, kui kellelgi mingeid väiksemaid asju vaja on, andku teada.
Lihtsalttiit
postitati 03.07.13 18:35 / uuendati 03.11.13 12:22
up
Lihtsalttiit
postitati 25.07.13 09:31 / uuendati 03.11.13 12:22
Up
rainer79
Registreerunud 30.10.12
postitati 13.08.13 09:08 / uuendati 03.11.13 12:22
skoda
Tere,
Kui palju maksab kapott ja esimene tuli (vasak)?
Kas kapottile peaksin ise järele tulema?
Ise asun Tallinna lähedal
Ette Tänades,
rainer79@gmail.com
Rainer
gurja
Registreerunud 04.12.09
Auto: Oktavia tour combi 1,9TDI PD
postitati 03.11.13 12:22 / uuendati 03.11.13 12:22
Palju esistange eest tahad? Kas esi istmed on sooendusega?
XMB Škoda Club Edition
[PHP: 40.4% - SQL: 59.6%]
