Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Superb I kliima valgustus.
Pealkiri: Superb I kliima valgustus. (Vastuseid: 1 | Vaatamisi: 2762)
Superb484
Registreerunud 15.09.14
Auto: Superb
postitati 28.08.15 05:46 Tsiteeri
Nimelt juhtus eile, et sõidu ajal kustus kliimablokil taustavalgustus kuid muidu numbrid ning muud näitajad jäid alles. Välistemperatuuri numbri asemele tulid kriipsud. Kas need on kuidagi omavahel seotud või lihtsalt oli kokkusattumus?
On sellist asja mõnel teist ka juhtunud ning teate, mis võis blokil juhtuda?
Veakoodid mis diagnoosi alt sain, naitas:
538 - CAN-bus
53d - estate
...aga mis need veel tähendavad?
Tänud vastuste eest.
tnx
Registreerunud 07.05.12
postitati 28.08.15 08:33 Tsiteeri
Googel sõber.
http://forums.vwvortex.com/showthread.php?6935204-Climatronic-Diagnostic-Mode-Reference-Guide
If an error is encountered error codes will be displayed as a hexadecimal number in the left hand temperature display. You need to convert the hex code to decimal (you can use an online converter like this one). Then you can take the decimal equivalent of the code and check it in the Ross-Tech Wiki URL. For example: hex code 0E5 = 229 in decimal = http://wiki.ross-tech.com/wiki/index.php/00229 in the Wiki, which is the VCDS page for the coolant fault pressure.
538 kohta siis see leht: http://wiki.ross-tech.com/wiki/index.php/01336
53d ehkt 01341 kohta seal infot pole.
XMB Škoda Club Edition
[PHP: 36.3% - SQL: 63.7%]
