Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Octavia III päevasõidutuled udukatesse?
Pealkiri: Octavia III päevasõidutuled udukatesse? (Vastuseid: 4 | Vaatamisi: 2851)
Online
Registreerunud 05.04.15
postitati 04.06.16 11:57 Tsiteeri
On selline asi võimalik? Kas keegi tegeleb sellega Tartus?
urmas66
Registreerunud 28.05.15
Auto: Fabia HB 1,2TSI 81kw 2016; MB Vito 4x4 119Bluetec 7Gtronic 2017; Oli Octavia Scout 2,0TDI 135kw 2015
postitati 05.06.16 06:05 Tsiteeri
See on täiesti võimalik.
Pead mõnel elektrikul laskma vedada mõned juhtmed,mis lähevad läbi relee,kus relee on lülitatud asendis,ilma toiteta.Kui nüüd lülitad pealülitist gabariidi või lähid peale(releele läheb toide peale ja katkestab sealt läbimineva ahela),siis päevatuled kustuvad ja saad ka udusid sihipäraselt kasutada.Ei ole raketiteadus,iga autoelektrik peaks sellega hakkama saama.
M.Jaaska
Registreerunud 13.01.14
Auto: Välismaa auto
postitati 05.06.16 10:45 Tsiteeri
Veidi keeruliseks ei lähe?
Octavia 3-l peaks selline asi läbi kaabli ka võimalik ikka olema.
Kui nii siis peaks kunagi uurima. Number on allpool.
levwfreaks.eu - Meie uus koduleht._________ Sõidad jälle ja naeratad! Forss
... Magnus
urmas66
postitati 05.06.16 20:10 Tsiteeri
Ma pidasingi silmas seda,et kuskil kust udukate toide algab,mitte seda et tulede peale vedada.Kui päeva tuled juba olemas,siis veel lihtsam.
tnx
Registreerunud 07.05.12
postitati 06.06.16 06:23 Tsiteeri
3 päringut googlesse juhatas sellele lehele
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/
mis siin foorumis ilmselt varemgi viidatud on olnud. Seal on õpetus olemas, kuidas programmiliselt võiks seda saada muuta. Sh jäi ette vihje, küll ilma täpse õpetuseta, et erinevalt Urmase soovitatud releega süsteemist peaks sellisel juhul udukad päevasõidutule reÅžiimis põlema osalise võimsusega. Võimalik, et need dimmwert numbrid määravadki seda.
XMB Škoda Club Edition
[PHP: 37.7% - SQL: 62.3%]
