Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/skoda/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 149
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/skoda/db/database.interface.php:33) in /data01/virt4271/domeenid/www.audiclub.ee/skoda/header.php on line 156
Eesti Skoda Klubi - Superb 1.8TSI
Pealkiri: Superb 1.8TSI (Vastuseid: 6 | Vaatamisi: 4629)
STR
Registreerunud 26.06.16
postitati 18.06.19 13:10 Tsiteeri
Superb 1.8TSI
https://www.auto24.ee/kasutatud/auto.php?id=3087848
Kuna pikemalt müügis olnud siis uurin siit, et ehk keegi käinud vaatamas / kuskil kontrollis / oskab miskit kosta? Hetkel just otsin Superbi, bensiinimootoriga ja automaati ning see jäi silma kuna keskmisest parem varustus ning võrreldes paljude teistega, võrdlemisi väike LS. Tänud ette!
Skoda Superb Elegance 2.0 D 4x4 2018
AllParts - sõidukite varuosad, kereosad ,tuningosad jne.
rstdi
Registreerunud 05.01.07
Auto: RS TFSI dsg O2 11, Cupra ST 300 4drive 17
postitati 19.06.19 06:25 Tsiteeri
Ma arvan, et kehtib kenasti siin teemas mainitud info:
http://foorum.skodaclub.ee/viewthread.php?tid=5046
Täpsemalt võiks teada esindus.
STR
postitati 19.06.19 07:24 Tsiteeri
Tänud!
Ise küsin ise vastan:
Esitiivad roostetavad;
Tagatiivad roostetavad;
Ukse alumised ääred kõik roostetasid va. tag. vasak kus ei märganud roostet;
Esistangel kriipsud kraapsud värvikahjustused;
Skoda embleemid mõlemad kulunud;
Sisu kohta müüja ütles, et esiistmed määrdunud kuid kogu salong on määrdunud kõvasti;
Tag. p. polstris pisike auk;
Mootor tundus käivat normaalselt kuigi ketiliini pool kuulsin mingit "knock" häält mida mu 1.4TSI 2014 ei tee näiteks, võib olla see norm sellel ja peabki nii olema;
Koha peal käike vahetades vahetas ilusti ja mitte midagi ei tundnud aga kuna DSG siis ilmselt see ei näita midagi kuna masendus oli nii suur siis proovisõidul ei käinud;
Õ•li väidetavalt ei võta kuid õlikorgi ümbrus oli ikka poole katte ulatuses õline, mitte küll värske aga siiski. Kõik siis järelikult varasemalt täiesti mööda valanud. Õ•likorgi enda ümber muidugi olid mingid puulehed ja mis iganes praht veel, et sellest võiks järeldada, et ehk tõesti pole korki viimati näpitud või siis ei huvita see praht seal.
Teisi asju isegi ei hakanud proovima kas toimivad.
Omanikuga kokku saamine tundus lõpuks ülikeeruline kui mitte võimatu, just ajaliselt.
Suhelda tuleb inglise keeles. Hinnas alla ei taha tulla kuigi Aprillis oli hind 5750 Eur, hetkel 5500 Eur.
10.04.2019 ja 184 000 km on käidud Skoda Tallinnas ostu-eelses. Kui uurisin, et mis seal siis leiti väidab müüja, et ei ole käinud auto Skodas kontrollis. Skoda ise seda infot kahjuks välja ei anna.
Hooldused on tehtud kuni 90 000 km margiesindustes. Peale seda väidetavalt hooldusi teinud omanike tuttavad mehhaanikud.
Jutu ja kuulutuse järgi on auto ideaalses korras. Reaalsus on hoopis midagi muud. Et keegi ei raiskaks samamoodi oma aega, leppides kokku aega kokkusaamiseks kõige pealt üsna pikalt, ning teiseks, et minna kohale arvates, et näete väga heas korras korralikku Superbi, kirjutan. Reeglina nii ei tee kuid hetkel kuna kuulutuses ja müüjaga suheldes pidi olema tegemist ideaalse autoga, kirjutan reaalsusest.
NB! Hind on ka 5500 pealt peale mu vaatamist ja kommentaare müüjale kukkunud 4900 Eur peale :D.
rstdi
postitati 19.06.19 08:14 Tsiteeri
Eks selline masin ongi see, ideaalses korras Eesti auto. :D
fuzzz
Registreerunud 16.02.15
Auto: Skoda Kodiaq 190hp TDI Elegance
postitati 19.06.19 08:21 Tsiteeri
Tahtsin juba enne kirjutada et selles hinnakalssis midagi korraliku paraku ei ole võimalik saada...korruta selle korvi hind kahega ja hakkab juba nägusamaid pille leiduma.
STR
postitati 19.06.19 12:28 Tsiteeri
Ma usun, et saaks ikka, aga eks korralikul ja "korralikul" on omakorda vahe. Ma isiklikult niikuinii selle koha pealt liiga pedant ja teen autod alati "enda jaoks korda" ja räägin kõik ausalt ära mis viga, et keegi ei hakkaks koha peal vigisema või hiljem kuid kirjutada infosse, et ideaalses korras ja siis ootab ees sind selline auto, on ikka täielik lollus. Eks vigu ole ka neil x2 hinnaga autodel. Kasutatud autod ju ja Eestis sõitnud enamus. Eks otsin edasi :).
fuzzz
postitati 19.06.19 16:57 Tsiteeri
Algselt postitas: STR
Nõustun...paraku on see äri eesti moodi et aina huiaks kuis jaksaks.
Mida iganes mina müütan räägin nii nagu asi on ja mis iganes puudused või tehtud vahetatud. 90% sõidukiomanikele on auto tarbeasi ja käitutakse ka vastavalt. Mina olen pedant kahjuks ja iga kriips ja täke ajab tohutult närvi.
XMB Škoda Club Edition
[PHP: 42.0% - SQL: 58.0%]
